jay1983
hi every1,
after doing my introduction i am now going to tell you my story.
ive purchased my 1st merc and have had a few issues in the 6 weeks ive owned it.
first was the AAM replacement, this was done by mercedes benz stockport, for the grand total of £430 (part and labour) Finally i had central locking and alarm. plus all the other things the AAM controls!!
Next was the AUX/serpentine belt. this was looking a bit shoddy and gave me no confidence at all. so purchased new 1 from ECP £28 and fitted myself. now i have a noisy tensioner so thats the next job.
at the moment the car is in SPR Autos Stockport, with starting problems. it turns over but doesnt kick. when its running however it is perfectly fine, apart from the 3 times it has gone into limp mode!!!!!
no idea how much this is going to cost me lol.
next up is new tensioner, waterpump and thermostat which i am going to replace myself.
couple of niggling problems however........
engine coolant light is on all the time, ive been told it could be the 75 amp fuse on battery terminal, ive checked this and it looks ok but the solid metal fuse part does not touch the metal on the 3 wires that it connects to? (if that makes sense) could this be the problem?
plus the car never gets above 80 degrees when its idle it wont go above 40 (and the fan doesnt come on) is this normal? if not will the thermostat fix this?
any input appreciated and i will keep this updated as the problems get solved to help others (hopefully)
