2001 W210 Heated Seats
Voyager
hello - have a question
The two front heated seats on my car have stopped working, however the switches that activate them still illuminate.
Is there one fuse for both seats or could it be something else ?
It'd be unlikely the connectors for both seats would become dislodged at the same time......
Thanks:wallbash:
bob6600
AUDI S8 V10, S210 E320 CDI (R.I.P.)
Check fuse 12 under the bonnet and fuses 17 and 18 under the rear seat
OP
OP
V
Voyager
thanks for your reply bob6600
I've done as you've suggested; fuse 12 and 18 is ok but fuse 17 was not installed. Funny, because i haven't been in the rear fuse area for months and am sure the heated seats have worked since then.
To add another element to this - the passenger seat seat omit a little bit of heat to one side and the driver is still dead. Strange as they used to be piping hot - can imagine all the heating element going at once as they're wired in parallel and should continue working when an adjacent one fails ??
mm?:dk:
OP
OP
V
Voyager
thanks -pls see below
