2002 110cdi Vito
Steveo666
Can I retro fit Cruise control? or do you need ABS (which I dont have!!)
I really like this van even thought they get a bad press due to rust and injectors etc. Its been a great van but could be made so much better if I can plug and play cruise...............anyone??????
Hi ya, yes you can but it isnt as simple as it first appears but is doable and no you dont need abs.
Martin
Thanks Martin
I will have a go at fitting it myself. Are there any "How To" articles?
Do you have any idea where to get the parts other than the local MB dealer (Truro)
Steveo
hi ya, it will need coding to the ecu i believe but you would have to check, ebay item 140423716173
Cheers Martin
Hi ya, Kingpin also did a very good write up about retro fitting cruise which gives you an idea of what might be needed, just do a search
Martin
Ok so I now have the indicator stalk
Does anyone know a good place in Cornwall that will do the ECU coding
Might be getting ahead of myself (I think I may need to build a loom first!!)
I need to get the van resprayed too, any recomendations for the Cornwall area?
Steve
Walsi?
