2002 c class brake lights on all the time
surfer73..
birmingham
2006 ml63 AMG
hi all
i fianally sorted out the oil in loom problem finished doing that today
:rock:
but now i have a problem with my brake lights being on all the time even when i remove the number 62 fuse from the fuse box the lights still stay on
can anyone help with this :doh:
cheers steve
your brake light switch under brake pedal is stuck it needs to be pulled out the white , grey part
reset the brake switch
easy fix
when you pull it out it sounds like a ratchet and clicks then when you use the brake pedal for the first time you will hear it again till it resets itself then you should be ok
hi
thanks for your help i will get under the pedal tomorrow and check it out
only one problem there now when i checked the brake fuse i stood in some dog sh*t
and thats on the carpet now lol
i just can't win with this car lol
take the mat out and hose down good luck
if you cant reset switch its ok their cheap 10/15 pounds or less
