2002 ML270 CDI few problems
KNU7S
Gloucester
1991 R129 500SL Mercedes, 2002 ML270cdi, 2004 Freelander
I bought the ML over a week ago and a few niggles have become apparent.
1, The drivers side mirror glass seems tinted however there is a clear band at the top and the tinted area seems to be a liquid??? anybocy know what that is?
2, Few patches of rust which I will treat and tidy up myself
3, The ABS, ETS, BAS/ESP and EPC lights occasonaly come on, I have asumes this is the brake light switch which I have just ordered (£10)
4, When the above lights are out the ABS sometimes is over sensative.
5, Some times the traction control will come on even if I am putting away slowly.
Any ideas??
Many thanks
Bobby Dazzler
MB Club Veteran
Mittel England
ML AMG-line Black Series
Any ideas??
Many thanks
1. Autodimming mirror has fluid in it, sounds like yours is leaking - straight replacement.
3. Likely suspect and worth it for a tenner.
5. Sounds linked to 4.
OP
OP
KNU7S
KNU7S
Gloucester
1. Autodimming mirror has fluid in it, sounds like yours is leaking - straight replacement. Thanks I will order a new one
3. Likely suspect and worth it for a tenner. My thaughts exactly
5. Sounds linked to 4. Im thinking it is probably a dodgy sensor or even a damaged wire what do you think?
Bobby Dazzler
MB Club Veteran
Mittel England
The mirror won't do any harm - watch eBay for the right one to come up - and check out the likes of euromerc (Nick) as they're pricey from MB - £330 for my C-Class!!
Give it a couple of days after replacing the switch (and clear any faults if possible) to see if it helps - all systems interlinked.
jaymanek
Nuneaton Warwickshire
be careful with the mirror, if that fluid starts to leak out and hits the bodywork, its worse than paint stripper.
OP
OP
KNU7S
KNU7S
Gloucester
Thanks for that!!! I have located on on ebay but am wondering if i just fit a normal mirror.
Thanks for all your responses
alyaly
mercedes ml 270 cdi 2002
hi mate i have the same problem.
did you find out the solution
