davidknell
- Jun 3, 2007
Hi all -
I've a 2002 SL55 which has been in storage for the last few years - been started from time to time and driven a few feet forwards and back, but otherwise just sat. I went to extract it last month, and it started fine, drove it out, left it running for a few minutes to warm up, turned it off.
Now it won't run - it'll start fine, run for a few seconds and then die, sometimes coughing a couple of times on the way. First thought was stale fuel - so I added four gallons to the gallon already present (I'd put it away without much fuel in) but this hasn't made any appreciable difference.
My suspicion is still fuel - either a clogged filter or a pump incapable of delivering enough to maintain fuel rail pressure once the thing's started. Unfortunately the fuel rail pressure doesn't appear to be available through the OBD2 connector, which would have been instructive. The fuel pump relay clicks on and off when I would expect it to.
Any advice before I start groping underneath for the fuel filter?
Thanks --
Dave
Thanks --
Dave
