Hi all.
I bought a Mercedes SL500 on 5 August 2014 from a Mercedes Dealer. The car looked stunning but had a few of issues. Despite, giving them 2 chances to fix it, they haven't, so i'm giving them chance number 3!
I just wonder if anyone might be able to help 'diagnose' what might be going on albeit I understand the difficulty this poses without actually seeing the car!
1.There is a nearside rear rattle which I can only hear with the roof down. It sounds like loose metal, is only present when the car is moving and seems to happen on uneven/rough road surfaces. One of the senior technicians came on a test drive with me and thought it was the brake cable (I wasn't convinced). They said they 'fixed' the brake cable yet the noise is there;
2.There is vibration/rattle/creaking noise heard from the windscreen/centre console area. It sounds like it could be coming from the engine bay. It is not present when stationary or idling but happens when accelerating either slowly or quickly. It also happens when the car is on cruise control and the car needs to accelerate slightly to maintain its speed. The technician said he thought it was the wheels not being balanced and re-balanced them all. I was far from convinced by this and although they 'repaired' it, it is still there!
3. There is also an obvious rattle coming from the engine when idling after cold start up. I got flagged down by a colleague who heard it and once I got out I could hear it (maybe its related to the vibration/rattle/creak that can be heard from the windscreen/centre console area). Having spoken to the main dealer, they tell me that the car is flexible and isn't as stiff as other cars. I told him that it happens when the car is stationary, so what has this got to do with the cars chassis. He then told me that these cars have idiosynchratic rattles. Does anyone else have a SL500 that rattles like mine?
4.The keys work intermittently - on occasions the car refuses to accept the key when trying to start the car and the other day the car would not lock. Today I locked the car and I saw it lock as I watched the door locks go down. However, when I was walking back to my car a few minutes later, I could see the door locks were in the raised position (before I was close enough for the key to re-open the doors). The technician thought it might be the batteries so replaced them in both keys, this hasn't worked.
5. The Sat Nav does not find satellites. They tell me this is the aerial, I hope they get this right as so far they've not had much luck!
6. Water pours into the boot when raising the boot lid and its raining. I have been told that this is normal and that there's nothing they can do! It seems to me like the seal channels aren't deep enough for the amount of rain. He tells me that the drains become blocked (I told him that they have told me that they've cleared them twice now)
7. The roof leaks inside the cockpit on the passenger side, where the roof mechanism can be seen.
8. Does anyone know if there are screw caps which cover the screws in the foot well as i'm sure I had some and now they are missing after they last 'fixed' the car.
9. The boot is temperamental. Sometimes it opens first time, but most of the time it needs to be tried 3 or 4 times (when using keylessly). Also, when using the button the remote I have to press it a few times. I have been told that this is normal, that it is the SAM module and that it will always be a problem. The other day it kept re-opening and seemed like the soft closure wasn't working. 7 attempts later it closed.
I thought getting an older car from a main dealer with the promise of the car being "in perfect working order" was sensible, but it has proven to be troublesome. My last merc had a few problems but the dealer fixed everything first time!
