2003 2.2 dMercedes Vito Driveshaft Flange NSF
sfiente
Vito
Hi
looking for some help - I've read numerous posts, so just want some clarity as the data sheet does not help.
I have a 2003 vito 2.2 diesel and the seal that connects to the output flange on the drive shaft is leaking gearbox oil. I have removed the nsf drive shaft and I am faced with this flange, which is held in to the gearbox.
I have read in posts that there is a pin that needs driving out first, but confused if this is for this side. I've also read that tyre levers will help pry this flange out and the slide hammer is only required for the other side (OSF).
Can anyone help? Do I need to buy a slide hammer to get this off or can this be prised off? Do I need to drive out a pin?
Part number for the seal is A6384110166, Part number for the flange that the seal sits behind is A6384101445
Any help would be much appreciated
