2003 C180 Kompressor erratic idle
Blueovalcraig
Mercedes C180k
Hi. I've been having issues with my car. It has developed a misfire/ erratic idle. I put my cheapie fault reader on it and it showed misfire on cylinder two. I changed the plugs and fitted a new coil pack and it was a lot better but it still has this erratic idle where it sounds as if it's 'hunting'.
I previously replaced the vacuum pipe which commonly fails and I have checked that again but it's fine and to be honest it doesn't sound as if it's drawing air from anywhere.
Could it be the timing ? I've heard that the tensioner can fail and cause the chain to jump a tooth.
All help gratefully received.
Auto-mobile
Birmingham
2x c43 Amg clio 172 turbo 314bhp
There is another pipe under the supercharger, I could well be timing jumped also, misfire faults and cam sensor faults usually mean timing issues.
jpod
Merc C180k 2005
If you change the one under the supercharger please take pics and post a detailed write-up, would be appreciated.
I used this to take the airbox off and look at the MAF https://www.youtube.com/watch?v=_EhnRhqPuHo
How many miles has the car done?
OP
OP
B
Blueovalcraig
Mercedes C180k
The car has done 79000 miles. I've got it in my head that it's the timing. If it is I'll be selling it for spares or repair as I don't have the time to strip it down myself ( I'm a mechanic to trade but have an office job now ) and I can't afford to put it into the garage
OP
OP
B
Blueovalcraig
Mercedes C180k
Spoke to my old boss at the garage where I used to work. He's going to do a compression test for me.
If the timing has jumped. How much could I expect to get for it if I sold it spares or repairs.
OP
OP
B
Blueovalcraig
Mercedes C180k
Ok so I finally stripped it all down and see thet the inlet cam has jumped one tooth. Do you guys think that I might get away with replacing the chain, guides and tensioner and not having to replace valves?
OP
OP
B
Blueovalcraig
Mercedes C180k
Have ordered a Timing Chain and tensioner so hopefully it'll run ok
m11ler
west midlands
volvo v50
Check the top cam shaft sprockets. If the teeth have worn or missing any sell for spares . As can be expensive if your not doing labour yourself. Chain stretch can happen in these cars
OP
OP
B
Blueovalcraig
Mercedes C180k
Cheers M11ler. Sprockets all look ok luckily. I just want my car back lol
Seat
Congratulations on winning your car in one piece.
Cheers
OP
OP
B
Blueovalcraig
Mercedes C180k
Got the old chain off. Looks to have stretched about 1/8 inch. Will post pics later but what a pig of a job.
OP
OP
B
Blueovalcraig
Mercedes C180k
Started car up and it's still got a bad misfire backfiring through air inlet. Looks like I'll be taking the head off to replace bent valves
m11ler
west midlands
volvo v50
I have a complete cylinder head off a 2003 c180 coupe 1.8 auto. if any of the parts are of use to you £100
OP
OP
B
Blueovalcraig
Mercedes C180k
I had the timing marks aligned and turned it over by hand a few times before putting it all back together
patso84
Mercedes C180 Kompressor SE Auto
Any news yet, mate? I bought my C180 Kompressor Auto 2005 in May,have done less than 500 miles on it. Engine light is on, started sounding like a diesel osn idle,rpm not stable on idle and looks like consumption is above normal. Brought it back to dealer,refused to pay my money back, but agreed to repair it...if not repairable will refund. I am reding your thread and waiting to see how you fix your car. You mentioned on the beginning about a vacuum pipe that usually fails...which one is that, any pics and details please?
Hope you will fix your car soon!
OP
OP
B
Blueovalcraig
Mercedes C180k
The vacuum pipe I replaced was the one that goes from the air feed, down the side of the Supercharger. It joins onto another vacuum pipe there which runs under the supercharger and into the block. I'm taking my cylinder head off this week to see what valves are bent. I will take photos of these vacuum pipes while I'm at it.
Sounds to me like you need to change your timing chain, tensioner and guides.
patso84
That is what they are going to do at least...starting with Timing chain kit, hopefully sprockets and valves are ok. I have not driven the car much with these symptoms. Tried to keep my foot between 1000 and 2000 rpm max. Have done about 100 miles maximum with this bad sound like diesel. Will take a look of these pipes when you post pictures. Good luck, mate!
OP
OP
B
Blueovalcraig
Mercedes C180k
Turns out I'm a ****. I double checked around the engine bay and discovered a loose earth and an unplugged sensor. Sorted them out and bingo, cars running sweeter than ever
