Hi all,
My 2003 E220 CDi S211 Estate had for the last 6 months a small leak from the front vertical side of the Engine OIL SUMP. The sump had gone porous from the FRONT (not far from where its screwed into engine) and oil would seep out through the metal on to the anti roll bar and then to plastics trays!!
My local garage tried TWICE with something called "chemical metal" but the leak would come back.
Over last weekend, I put the car on stands, removed the under body trays and drained the oil. Then used the entire tube's well mixed "marine putty" on top of chemical metal, covered it well from all sides and let it dry/ cure for 24 hours before putting the oil back.
All was fine until last night when the dreaded leak came back.
My mechanic has now advised to try one of those engine oil leak bottles that you add to your engine oil and it cures the leak after some time. But every bottle I look at only mentions seals or gaskets, does not mention porous metal sumps.
Can anyone give any suggestions/ recommendations about which one to buy?
Anything else I can try?
Thanks in advance for your replies.
