Morning, following a thermostat change a couple of weeks ago where I lazily didn't drain the coolant I've been suffering with the car being stuck in limp mode. I mention the thermostat change as I hosed off the spilt coolant after the job, possibly a costly mistake.
The stored and current code according to icarsoft that comes back is:
P2110 Y100/1 Right charge pressure positioner, Sort circuit to positive. I've disconnected the electrical connector, cleaned everything up with contact cleaner and reassembled, with no change.
If I leave the turbo disconnected the fault code changes to :
P2112 Y100/1 Right charge pressure positioner, Signal line is interrupted.
This leads me to conclude that the actuator is indeed fried rather than an actual wiring problem. Does the logic stack up or is there anything else to check?
