E240estate
- Aug 19, 2014
- 2003 S211 E240 Estate; 2003 W638 Vito
Hi, as title, no fuel at fuel rail, car can be made to start by applying 12v directly to the fuel pump.
Fuel pump does not come on when key turned on. No 12v at fuel pump connector when ignition on.
Power on both sides of fuse, fuse ok.
Relay from rear SAM tested off the car and works perfectly.
Tested all relays in front SAM all good.
Car not sending 12v to fuel pump
No codes.
Sudden failure.
Next step for me is to remove and inspect rear SAM, correct? Or any ideas from anyone on here much appreciated as always.
No codes.
Sudden failure.
