Hi, I'm the owner of a 2003 E320cdi with approx 122k miles on the clock.
I have an issue relating to the self-cancelling of the indicator stalk - basically it doesn't always cancel, or it will cause indication in the opposite direction. When steering there is also a clicking noise and mechanical resistance can be felt as if something is broken.
I have a new stalk on order and torx bits that will fit in the recesses to allow me to remove the air bag. Reading around the various Mercedes forums there are some cases where another part was the culprit (basically a plastic cam mounted to the column), which I think is shown on figure 10 on this excellent guide:
Pelican Technical Article - Mercedes-Benz W211 - Steering Column Switches Replacement
I've really struggled to find a part number for this item although some on american forums have managed to replace it. I'd really like to try and avoid having to the job twice.
I have access to Mercedes WIS and the EPC and I can't find mention of it anywhere. I quizzed the dealer's parts department who also couldn't find it and suggested it may be part of the clock spring or steering angle sensor, I don't think it can be. He did say it is usually the stalk itself that fails.
Does anyone have a number for this. I think I've found the equivalent part for older models (1404620751), does this also fit the W211?
Thanks,
Richard
Thanks,
Richard
