Hi ...I want to send my driver-side seatbelt for repair, so I need to remove it. I have made some progress, but I don't know how to remove the lower rear side panel. I have found plenty of documentation online with diagrams (AR68.30-P-4780Q, AR91.40-P-0630Q, etc), but there is no detail on how to actually remove the panel(s) ...it just states 'remove'. However, I don't know how to remove the panels and don't want to break anything by forcing things off.
It could be that I need to remove other components first. In the photograph below, it's the orange panel that I'm trying to remove. The green rear seat cushion is now loose. The purple is foam padding which I assume may be attached to the orange or blue panel (although it could be unattached). The blue panel runs up to the ceiling and seems to overlap the orange panel, but I see no way of removing it.
To the bottom left (out of the photograph), the orange panel is tucked under some plastic door sill trim - not sure how to remove that either - is it just a case of pulling it upwards with force?
View media item 8661
The sort of info I'm looking for is, the order in which I need to remove the panels, and whether there are latches to undo, plus the direction that I should pull when removing.
Any info/help would be greatly appreciated : )
