2004 CLK 320 Electrical Gremlins
kenam
NI
2005 CLK 320
Not sure where to go next in this diagnostic journey and hoping one of you kind folks will have some advice.
Got an old clk 320 with some weirdness.
Symptoms:
- Have an ESP dashboard warning (ESP disabled, visit workshop!).
- Secondary fuel fan has issues (runs on when engine stopped, only way to stop it is pull the fuse).
- Horn has intermittent issues (mostly doesn't work, have tried replacing one horn, no change) but can hear the relay click when horn pressed.
Investigation done:
- Steering wheel wasn't sitting straight after getting suspension fixed so had it aligned and tried to reset ESp by turning full lock left right - still got the warning.
- Plugged into star system and got:
9000 - control unit N80 (Steering column module) is defective.
C1172 - N49 steering angle sensor - internal fault
Other notes (that may or may not be relevant..)
Most of the fuses for these all are in the engine bay/drivers side box.
There is water ingress in the rear of the car near the back fuse box.
Had a driver display warning to replace side light bulb (bulb was also not working).. but it started working again after a week..
I was (via a mix of ignorance and googling ofc!) thinking that this points to front sam module, but would that give those fault codes? Would the steering column module resolve the fuel fan issue? Or am I looking at two or more different issues here?
Not sure what to do next and feel it might be time to part company with the ol' 320 😭.
check your water drains for blockage, second time this is happening to me, thankfully no electronics were damaged but a lot of cables pass through where the water accumulated inside the car
I'm have a look thanks! - I guess this sort of thing?
not sure on yours, mine are a straight "pipe" going down at the front where abouts he is showing. I also have a sunroof and the rear ones need the black plastic seal of the rear boot removed to be cleaned up.
We took the passenger side carpet off until it dried, and also the roof lining. If you put them back in wet, your gremlins will return.
