2004 E55 N/S mirror heating
smoothcoupe
WEST YORKSHIRE.
MERCEDES E55K-2001 AUDI S8-MERCEDES 300CE 24V SPORTLINE
Hi all. With the cold weather coming I’ve noticed my passenger side wing mirror is not defrosting. Does this work on a separate fuse from the drivers side or is another issue causing this. Any ideas guys???
More than likely broken wire in the housing or terminal on the mirror. Mirrors typically log a fault code that tells you what exactly is wrong them. I’d get a scan on the car done and take it from there.
As above, most likely a broken wire
