2004 ECLASS COMMAND SYSTEM
hgv1
cheshire
e320 w211
hi all
command system gone crackers cannot change date on command system greyed out on screen
does it have to be done through star ?
I think this has something to do with changes in the gps signal which syncs the date and time. My 06 GL date is wrong and can’t be changed. Doesn’t seem to cause any issues so have got over it.
1. I would try a firmware update just in case, I believe that on a 2004 E-Class this can be done from a CD, i.e. no need for STAR?
2. There may be an option that says if the time is received automatically from GPS, or entered manually - worth checking this.
I had 2 S class neither ever could be set to the correct time always 10 minutes one way or other. Very frustrating.
HI
you was right gps signal went back on now
thanks
