Mercedeschris
Having a strange fault on my SL500 recently. It has keyless go so don't often use the EIS key. However I tried to start the car with the key the other day and it wouldn't turn at all?
If I disconnect the battery and reconnect it, the key will turn as normal. But if I remove the key from the EIS, it won't turn again unless I disconnect and reconnect the G1 consumer battery.
I've tried both keys and same result.
When I plug my iCarsoft in it says no faults in EIS?
Anybody on here had a similar issue?
TIA
TIA
