If you're considering an R171 SLK200 then I would suggest going for a 2008-on R171 facelift (184PS) with a 6-speed manual gearbox. The auto is quite dull, but goes just as well. Also consider sport pack (you get bigger brakes, nicer wheels, lowered suspension and the lip spoiler on the boot lid).
The one we had was a poverty spec facelift 200 with manual box and would have benefitted from sport pack.
Those that say the 200 is for the faint hearted and skirt wearers, I say this. When we went on run outs with the guys from the SLKworld forum, our 200 held its own very well with the V6 and even V8 variants. Sure in a straight line they could pull away, but whenever things tightened up a bit on the B-roads, if we were in front we could drop them from time to time. It's not all about power and 0-60 times.
All that said, if you can find a facelift R171 350 with a 6-speed manual gearbox on 17" rims... those pedal along very nicely.
Edit - If you're considering a 280/300 (3-litre V6), look for one with sport pack. The standard spec on 16" rims has the same or similar one-piston front calipers that the standard 200 has which are not the best.
