wu56Shoozz
- Jun 17, 2016
- MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
I've labelled the above specific to mine but as far as I know this issue affects other models in the range too..
My vehicle went in for service the other week and I was advised that the Brakes were low and that the front discs in particular were bad. So I went to order a set from the dealers down the road and.. straight away, my car has the sports pack on it, meaning that I have cross drilled discs. It was an option it would appear when the car was "built" by the first owner. I should have 330mm vented discs only. So I set about a quest to get cross drilled discs for the car as I like the extra stopping power it provides, with it being an auto and here's where the fun begins..
Set 1/ MTEC Cross Drilled - two near side discs supplied i.e pattern of cross drill is the same.. though it was a mistake, promptly sent back, only for the same set to return...
Set 2/ EBC - and the same again, two near sided discs same pattern supplied..and returned..
Set 3/ Pagid - and the same again.. two near sided discs supplied etc..
Set 4/ Brembo - now a mate of mine is an applications engineer in here so we had a chat and...
Did you know that there isn't an after market cross drilled front Off Side disc available at all Yup! No one makes an Off Side Cross Drilled disc with the pattern the correct way for the car? We spent ages researching this and cross checking with the manufacturers and its true, when ordering cross drilled discs for the front there isn't such a beast and that's why all the above supply two of the same nearside discs..
Just thought you all should know, and before you flame me go and look at your car.. you'll see the same. (Or provide photos)
