2007 115 Vito Dualiner - indicator always on
HollowPoint
W204 C220 AMG Sport Estate
Hey all, my mates Vito 115 Dualiner has its left hand indicators always on, all three of them. The right hand indicator works as it should, as do the hazards (although the left hand indicator stays on solid). The left arrow on the dash flashes rapidly (like a dead bulb would cause) when you move the stalk to actually indicate left, but the actual indicators all just stay permanently lit. They also continue to stay lit when you turn off the ignition!
So far, we have dismantled and inspected ALL light housings, we have eliminated them as the problem, as the issue continues with them unplugged. We have also eliminated the microswitch in the stalk, as we have removed the steering wheel and the stalk, disconnected the microswitch and the problem remains identical.
We are assuming, it's a stuck relay, or logic gate somewhere, however we cannot seem to find any documentation on where these things are located for us to investigate... does someone here know where it should be? Or have any other suggestions as to what might be causing the problem?
