blackadder
- Sep 5, 2016
- c class
the rear brake pipes are corroded at the wheelarch and need replacing. MB quoted over £500 to do the job. Silly money. So anyone done the rear pipes on this car to give me an idea as to what goes where. The off side pipe runs from the flexible at the arch across the body to the near side arch and then dissapears behind the wheel arch trim with the n/side brake pipe. I will have to remove the trim to see where it goes to. Is there a connection anywhere or do the pipes run all the way to the front?
