Knightrider69
Hi guys I've owned my cl63 for 3.5 years now and it's been great but the other day I got the dreaded low coolant warning on my dash. I couldn't see any visible leak or puddle under the car and I think my oil level has gone up (I last topped up the oil a few weeks ago to 3/4 on the dipstick and now it's reading well over the max mark - I also checked the coolant at the same time and the level was fine then). The car has only done approx 90 miles since I last checked the levels.
After reading all the posts on various forums from other unfortunate owners who had this problem I'm fearing the worst in that there is Headbolt failure and head gasket failure.
I called the AA out yesterday and the patrolman first did a pressure test on the cooling system (5psi) for about 10 minutes with the engine off and he said the system was holding pressure. He then started the engine and let it idle till the coolant got to over 80 degrees and the cooling system still held the pressure. After this he performed a head gasket failure test using a coloured liquid in a tube placed over the coolant expansion tank and it passed that test - he said if the head gasket had failed the coloured liquid would have changed colour which it didn't.
There is no visible sign of coolant contamination on the oil dipstick or under the oil cap. The engine runs fine and there was no white smoke from the exhaust. The AA patrolman said he thinks the car is fine but I'm not convinced as there is still the unexplained loss of coolant and oil level rising.
I was hoping for some advice on where to go from here, the AA said they will flatbed the car to a garage if I need to. If it is the head bolts I don't want to hydrolock the engine by driving it with 1 litre of coolant in the oil. Equally if it isn't the head bolts I don't want to spend thousands on an unnecessary repair.
Can anyone tell me what the best way will be to check and confirm if it is actually Headbolt failure - would the car have passed the pressure and head gasket test if it had Headbolt failure?
Thanks in advance for any advice
