2009 B180CDi alternator issue?
gcon45
W204 C220CDi Facelift
Hi guys.
My wife was driving home today and the battery warning light came on a few times. Afterwards a message appeared to say the car would shut down within 3 minutes.
She pulled over and I came out with a new battery and fitted it.
The car started ok but the battery warning light still comes on.
I brought the car into our garage and tested the alternator with the engine running and it shows 11.73 Volts, this would normally be around 14.
It looks like we need a new alternator. What do you reckon?
I thought the alternator belt might have broke but as it drives the power steering (and the power steering still works) I assume it must be ok.
Any advice / opinions?
Not sure with your model? You may be able to replace just the regulator/brushes. Try a Google on this. That will be cheap and quick.
Alt should push out up to 14.8 at 2.5k RPM.
Thanks for the reply!
Replacing the regulator / brushes would be a lot cheaper and are usually the cause of the problem.
A Bosch remanufactured alternator is around £300 + VAT then there's a good few hour's labour on top of that.
I'm just wondering if the B180CDi has an over running alternator pulley (clutch pulley)?
If this was faulty (ie - spinning freely without driving the alternator) then there would be no charge getting back to the battery.
Perhaps the pulley is solid on these though. I'm just surmising.
