- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
Hi All.
BIG PROBLEM this morning.
Put the key in - No panel display at all.
The panel is completely blank - Nothing at all - No lights - Clock stopped (although the time in the radio display is still running).
The turn-lights and emergency flashers still work but the panel repeaters don't.
The headlights come on when set to off, but go off when side-lights is selected.
Main beam only works when lights are set to on (3rd clockwise position).
Horn doesn't work.
Cruise control and speed limiter doesn't work.
Brake "HOLD" doesn't work.
There may be other things that I haven't spotted yet.
Other than the above - The car starts, goes OK - Stops OK - and appears to perform OK.
So far - I haven't done anything .
Could it be a fuse ? If so - Which one and where ?
Should I disconnect the battery and reconnect ?
Good advice needed - Urgently - Before I go to Rodley Motors and ask them to plug it in.
Horn doesn't work.
