Hi all,had a problem with my key,when in the on position before turning engine over all the dash and lights were working,when I turned the engine overy everything stopped working,indicators,lights on dash,Rev counter and speedo,after a while I decided to try my spare key,this has worked but the central locking now decides to work when it wants.
I’ve put a new battery in the fob and the little led flashes when pressed so it’s sending a signal. The interior light will sometimes stay on when the key is removed indicating it could be something to do with ignition switch?
Also how do I go about fixing the other key? Thanks in advance,mike
