ATJ
- Sep 14, 2023
- Location
- London
- Aston Martin DB9 6.0 V12 Tungsten. SL350 Iridium. BMW X5 M Sport Grey. C Class AMG Plus Obsidian
My second post in 9 months on here, so hello again. Also, probably confirms that the 50k miles, 2009 SL350 I bought has been “SuperLicht" on issues
Just a rotted-out fuel pipe and small C pillar leak both fixed very cheaply. However, there has to be a “However” or I wouldn't be writing this, I noticed yesterday for the first time an issue with the transmission on kickdown.
In normal use, the gearchages both up and down are very smooth. Even pressing it hard, the progression through the gears is fine. Perhaps the odd, light clunky downshift when it’s warn. Use kickdown though and it thumps/thuds through the gear changes. From standstill, P and D engage without a murmur or hesitation and there are no random changes or gear holds on a normal drive.
Has anyone come across this before? I’ve searched the threads and not found anything similar. It hasn’t had an ATF change and wonder if it’s just that the oil is losing its viscosity when warm, which is why it is getting the odd clunky downshift when warm.
Any pointers to the potential cause or anyone experienced a similar issue?
Thanks,
Alan.
Thanks,
Alan.
