logiedurno
Hi folks, I had an mot advisory for both my front shock absorbers lower bushes on my 2009 R230 SL350 being slightly worn (I guess they mean the ball joints) Apparently, the shock absorbers and coil over springs are fine. So my question is can the lower ball joints be replaced? They look like they may be pressed in but I’m not sure. Seems an expensive fix to change the whole shock absorber to sort out but if that’s the only option, are there recommendations for replacement shocks? MB original parts are, I think A230 320 1413 and quite expensive so a good quality aftermarket would be a more desirable choice. TIA..
