2009 SL350 R230 Rear Fuel Line/Pipe
ATJ
London
Aston Martin DB9 6.0 V12 Tungsten. SL350 Iridium. BMW X5 M Sport Grey. C Class AMG Plus Obsidian
The rear fuel line/pipe on my 2009 R230 SL350 has rusted through and is leaving petrol on my driveway. The part is no longer available through Mercedes and is not available from Germany either. I've trawled through Google and can't find any aftermarket parts or even used from a breakers. I've seen a number of companies that will supply the tubing and connectors but not one who will make up the line to replicate the original part spec (A2304701964). Anyone have any recommendations of a company who may be able/willing to build and supply this type of fuel line?
Thanks in advance for any help and suggestions.
Cheers!
Yep....go with Pirtek.....they have made me a couple of no longer available ALFA high pressure power steering pipes to a higher spec than stock and high pressure and low pressure AC tubes for my old 528i. Both were I mix of rubber and solid parts. Just take the old one too them and they will make it up in a day or so.
Good to know they will fabricate them from pattern. Thanks for confirming Pirtek as an option.
