peter01443
- Jan 17, 2007
Car starts and ticks over fine. On part throttle sort of ok. But once you give full throttle there is a loud induction noise, but no power particular at higher revs - wont rev much over 4000rpm. Going up hills is only really achievable on light throttle which means speed drops dangerously low.
Compression test gives high enough readings although the gauge builds up as engine turns over (I am told this suggests worn rings). Would this cause these problems? I am sure (as I can be) that there is something wrong with Fuel Injection or an air leak in inlet manifold (hence loud induction noise on full throttle). Possible?
I have a manual 200E which I can use to scavenge parts or engine, what problems might I encounter in swapping engines bearing in mind one is manual and one is auto?
I am too far away from anyone who has a Bosch diagnostic system.
Any assistance gratefully received.
PS: TE is 1991, E is 1990
