Tearaway107
- Apr 18, 2011
- SL 107
Hi Guys
As title, our S212 has had the infamous rear suspension dropping overnight when the temperatures are very cold.
Checked all pipework - ok
Replaced airmatic valve block behind the rear bumper with a new part to rule it out - made no difference
The suspension drops uniformly (not one side) so i need to rule out the pressure relief valve (which i think is on the pump / compressor). Is it feasible that we have a bad pressure release valve - and is this part replaceable on the pump?
Before we replace both rear air bellows which are very expensive i want to be sure that this pressure release valve is not the source of the problem
