2011 C207 E350 CDi - Cornering Lights
Guapito1973
Wokingham
Mercedes Benz E350 CDi Coupe
Hi. The right side cornering light on my C207 Coupe has failed and I cannot see how to replace it. There are two caps at the rear of the headlamp unit but these appear to be for the other bulbs. Can anybody advise? I have the bi-xenon lamp unit.
By the looks of the diagrams, on the Bi-Xenon lamp unit, the cornering light bulb is an H7; so if you found one of those amongst behind the access caps, chances are that's it!
Edit: it's common sense, but it's worth stating that you should always make sure the ignition is off when poking about around HID lighting systems. There is significant voltage at work.
I thought he meant the low down lights on the W211 shape . I didn’t realise that the newer models had cornering lights higher up :rolleyes:
The lower ones are just DRLs I think - they certainly are on the C204
