derektrotter
- Oct 12, 2013
- MB
Hi All
I have a 2011 W212 E250 and need 4 new tyres, checking the tyre wear I've noticed:
- Fronts - outer has a bit more tread then rest of the tyre but fairly level otherwise across the tyre
- Rears - the centre of the tyre has heavy wear compared to the outer edges.
I check tyre pressures regularly and they are always set correctly, I use the lightly loaded (3 passengers) PSI values on the sticker.
Is the above rear tyre wear pattern normal? I'm getting 4x new tyres anyway but am reluctant to also get alignment done if it does not need doing, car doesnt pull in any direction and steering wheel is dead on centre, car was brought from dealer and have not encountered any heavy potholes that i'm aware of.
Reason for reluctance in getting alignment done, my previous MB when I had tyres done they advised alignment was out, after they (F1 Autocentre) did alignment however car started drifting more towards the left when you let go of the steering wheel (prior to this it was dead on centre), when I took it back they advised thats how it is supposed to be on UK roads for safety reasons, didnt get a chance to check if that was accurate in the end as I traded it in when I purchased current car, dont want to go thru similar if I dont need to
As an aside any opinions on:
Goodyear efficientgrip XL
Continental ContiPremiumContact 5
Michelin Pilot sport 4
I've had the efficientgrip before and been happy with it, quietest tyre which I like but the Conti seems to come out higher in autoexpress and other sites..
