Noticed that the A/C is not blowing cold in my CLS W218 with the analog A/C panel. The red A/C light comes on and off when pushing the button as normal and no warning messages are displayed.
Simply said, all seems well, except the air does not get colder than the outside air. When regulating the temperature for higher temperatures hot air comes through as normal.
I'd like to trigger any diagnostics and A/C reset (read anywhere that the Climatic A/C has got a diagnostics and reset mode that can be triggered by the user) but don't find any information on how to do it in the conventional A/C system that equips the CLS/W218 as a standard.
Additionally I could check the fuses for any fault related with A/C. Regrettably I don't see anywhere in the vehycle a Fuse Designation List in the boot of the car in the spare tire cavity as the owners manual indicates.
I also read that this A/C system is completely sealed and that the probability of a coolant loss is remote. Am not sure if this is really the case, but given the low mileage of the car and only having 4 years of light use it might well be an electronics/sensor issue?
Could anyone in the forum please help indicating how to perform a diagnostics/reset of the W218 standard A/C or what fuses to check for?
Cheers
Cheers
