2012 220cdi
Discussion in 'Engine' started by pcthrillrider, Apr 16, 2019.
  1. pcthrillrider
    pcthrillrider Active Member
    64
    Feb 28, 2015
    chelmsford essex
    Car:
    2012 c220cdi blue effiency se executive
    my car seems to take forever to warm up this morning it took 14 miles till up to temperature,yet on way home from work it took 7 miles? is this normal or do i have a thermostat problem?
    this is my 1st mercedes diesel
  2. AMGeed
    AMGeed MB Club Veteran
    11,402
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    It should be warm within a couple of miles on a diesel.
    I would suspect a faulty thermostat. It should be reading around 85 -90C when fully heated up.
    If you decide to fit a new one, get an OEM one from the dealer, not an aftermarket part from ECP.
  3. CowleyStJames
    CowleyStJames Hardcore MB Enthusiast
    287
    Sep 26, 2015
    North Wales
    Car:
    Mercedes Benz S212 E350 Sport Cdi
    My 2012 E250 takes 10/12 miles to fully warm up in this weather, I shouldn't worry about it.
    How long was your shift?
    The engine may have still had some warmth in it, so took less time to warn up
    clk320x likes this.
  4. AMGeed
    11,402
    Nov 1, 2008
    Car:
    Does it really take that long, even in April to get warm?
    Not very efficient at all if it takes that long.
  5. clk320x
    clk320x MB Club Veteran
    9,176
    Sep 27, 2016
    East Midlands
    Car:
    W211 E320 CDI - W212 E250 CDI
    Edit
  6. AMGeed
    11,402
    Nov 1, 2008
    Car:
    Fair enough Abs. My bad. I didn't realise they are so slow at warming up;)
    Another reason not to buy a diseasle:D
    clk320x likes this.
  7. OP
    OP
    pcthrillrider
    64
    Feb 28, 2015
    chelmsford essex
    Car:
    i start at 05:45 and finish at 15:45
  8. OP
    OP
    pcthrillrider
    64
    Feb 28, 2015
    chelmsford essex
    Car:
    thats what i was thinking but arent they elec now? the on board computer can also turn off the water pump i heard
  9. clk320x
    9,176
    Sep 27, 2016
    East Midlands
    Car:
    Lol I agree!! Have been looking at e55s! :eek::D
  10. MercedesDriver
    MercedesDriver Hardcore MB Enthusiast
    1,397
    Mar 19, 2013
    Near the forest
    Car:
    S212 E250 CDI
    OM651 is ridiculously slow at warming up. I’ve changed mine last September (OEM thermostat) and still much slower compared to my all previous petrol Mercs. In slow traffic in the mornings it takes 10 minutes to reach 85-90 deg.
    AMGeed likes this.
  11. andym2
    andym2 Member
    35
    Aug 17, 2011
    Warwickshire
    Car:
    E220 CDI Estate
    Any particular reason not to fit the one from ECP?
  12. markjay
    markjay MB Club Veteran
    21,959
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    It's not EPC as such, it's just that many aftermarket thermostats are of poor quality.
    Buying an original one is the safest bet, though an OEM brand (e.g. Wahler) should also be fine.
    AMGeed likes this.
  13. Adam88
    Adam88 New Member
    5
    Oct 24, 2015
    Car:
    A45
    That’s quite normal tbh, I’ve drove down motorway for 20miles and my needle has just touched the right temp
  14. silver1011
    silver1011 Hardcore MB Enthusiast
    100
    Apr 11, 2019
    York
    Car:
    2016 W212 E-Class Saloon SE
    Diesels are far more thermally efficient compared to petrol, they'll always take longer to warm up.
    That's why most of them have ceramic heating elements in the vents and heated seats.
    If you're only travelling slow, in slow moving traffic or leave the stop/start system turned on, it will take longer to warm up, especially if it's cold and the heating system is calling for heat.
  15. CowleyStJames
    287
    Sep 26, 2015
    North Wales
    Car:
    In the winter, I tend to use the flappy paddles to hold car in higher gear to warm up engine quicker.
    Ironically, this was suggested by my MB dealer when I said how long warm up was taking
  16. TeddyRuxpin
    TeddyRuxpin Hardcore MB Enthusiast
    280
    Jan 10, 2019
    Cardiff / London
    Car:
    E350 CDI Sport W212
    That sounds like a bad idea while the oil is cold and thick... (if the revs are too high).
    The car does it automatically, to a safe degree, in any case
    clk320x likes this.
  17. Trickythemerc
    Trickythemerc Hardcore MB Enthusiast
    924
    Feb 1, 2015
    South Manchester
    Car:
    CLK 220 CDI Sport 2009
    Big lumps of cold steel and oil need to be warmed up under minimum load. Some folk think letting a diesel idle for a couple of minutes on a cold start is a good idea. Two things that are not good for cold engines are high RPM and being laboured by using too high a gear. On a very cold morning I let mine idle while I squirt the de-icer, set up the sat nav Etc. My usual route to the motorway is A & B roads with a 30 MPH limit and cameras, by the time I hit the motorway it is pretty much on the mark. I tend to keep off the throttle for at least the first 7 or 8 miles to give everything a chance to warm up fully. The car will hold the lower gears longer automatically in cold conditions.
  18. CowleyStJames
    287
    Sep 26, 2015
    North Wales
    Car:
    Don't hold the revs high, just a higher gear than it would itself
Share This Page
