Hello, newbie here, have recently purchased a 2012 C Class C180 Coupe, full MB service history.
At 39700 miles engine light appears on dash, fault code P0340 Camshaft position sensor. Diagnostics narrowed down to intake side - sensor duly replaced fault code cleared - approx 100 miles later engine light on again - same fault code. Again cleared but re-occurred shortly after, and has appeared intermittently since.
Have noticed cranking time to start engine is sometimes lengthy, also on start up the engine is noisy for a couple of seconds (sounds like a diesel).
After doing some research, I am wondering whether one or both camshaft gears (adjusters) are failing? This seems a common complaint on M271 engines. But the only reports I can find seem specific to earlier cars.
- Does this sound like a poss Cam gear(s) failing?
- Has anyone encountered cam gears failing on later 2012 models at such low mileage?
- Could cam gear failure affect cam position and hence sensor faults?
- Have replacement gears/adjusters been modified to eliminate repeat failure?
- Is there any customer support likely from MB dealer?
Sorry, lots of questions, this my first MB car I'm anxious to get some opinions.
Many, many thanks for any input....
