PaulPJ
Hi All, my 2013 W204 C220 is showing a message saying 'Front Right Malfunction Consult Workshop'. This has only just started after I took the car to a company to have the drivers seat cushion stitching redone. I can only assume they either took the seat out or at the least undid the bolts to enable them to remove the seat cushion. I have looked under the seat and I see 1 large yellow plug with 6 wires and 1 small black plug with 2 wires. Is it a case of unplugging or wiggling each of these plugs or is there one I have missed. Also, is it safe to mess around with these plugs as I know from the past that the airbag can go off if the battery is not disconnected.
Many thanks Paul
Many thanks Paul
