- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, SLK55, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
The car is a 2013 CLS with TPMS. A couple of weeks ago I had a flat (screw in the tread, managed to puncture the sidewall, completely flat, drove less than half a mile at very low speed on it to get home). I had a new tyre fitted, and about fifty miles later I had the yellow 'rectify tyre pressure' warning come up. The iCarsoft MB II brought up a stored code 'loss of communication', or some such, for the same wheel. Tbf, the pressure was 255 kPa as opposed to the other rear, which was (the correct) 250 kPa. I cleared the code; the pressures are now spot on, and identical, but the yellow warning still appears, for the same wheel. There are no associated codes.
Does anybody know, will the system reset itself after a while, or will it need more than that?
