xxaosicxx
Hi all,
First post...so please be gentle
My 2013 SLK350 has developed a short-but-loud rattle on start up which happens about 50% of the time - sometimes after a drive and a short stop, sometimes on a cold start. It usually lasts between 2 and 5 seconds, but sometimes lasts longer and is sometimes much noisier. At one point it was rattling so hard the engine (and the car) was literally ROCKING side to side for about 5 seconds.
As the warranty on the car expires at the start of March I dropped it off at MB Whitefield on Wednesday. It's still with them now (they're also fixing a leaky roof seal under the warranty, which apparently will take them a week!), and - of course - they're saying they can't hear the sound I'm talking about.
I've done quite a bit of googling, and reading up on other forums, and have some ideas about what the problem might be - but I'd really appreciate some direct advice from you chaps.
Potential causes I've heard of so far:
I do not claim to fully understand what each of the above means - but I really need my engine to not die on my out of warranty, so anything I can do to help the dealership determine the cause of the (apparently non-existent) problem would be great.
I've done a couple of videos, with sound, in case that would be any use to you all (I gave the same videos to MB).
Video 1
Video 2
All and any advice is greatly appreciated.
Thanks fellas.
Ben
- Secondary chain tensioners
- Non return valve in the oil filter housing being faulty allowing oil to drain away from the cylinder heads
- Knock caused by lifters leaking down
Video 1
Video 2
Thanks fellas.
Ben
