2013 Vito W639 - Positive battery clamp snapped - Advice sought
TechHead
Midlands
2013 Vito 116 W639
I'm hoping someone in the forum might have the knowledge for what I thought might be a fairly straightforward job :-(
I've got a 2013 Vito XLWB 116CDi.
I had my starter battery replaced on the van a few months ago back in June 2024 due to it's age and condition, thought all was good until a couple of weeks ago when I couldn't start it at the local supermarket, no power at all.
RAC eventually jumped me back into life, and I took it for an hours drive to get some charge in the battery. Took it home, switched it off, hoped for the best for the next day. Tried to start it the next day and nothing at all, not even power to the dashboard info screen.
Booked it into my local Merc commercial dealer to see if I could get the battery swapped on warranty and some tests completed, would be a few days until they could squeeze me in so I decided to test all fuses with a multimeter to see if any parastic drain on the system. All was fine.
Decided to unbolt the battery under the passenger seat and 'carefully' slide the battery out enough to take off the positive terminal cover, and loosen the battery clamps from the terminal. Moved it a few cms and the positive cable and clamp fell away with the cover, half the terminal clamp was still on the battery :-(
This positive battery terminal clamp has two post stands for additional items. Looks like it was soldered and then crimped properly.
Ok, so thought well, I'm not paying to diagnose something I've found the fault to so decided to do order the part number from Mercedes for the battery clamp by iteself based on them looking up my reg and chassis number, about £50.
It looked physically different and only had one stand off post but thought ah well, must have been small incremental changes over the years the model was being built.
Ordered a few parts I would need like flux, solder, heatshrink, etc.
Chopped off the current terminal clamp, tidied end as best possible, did quick eye up test with the cable and terminal clamp, and man, the cable is way to big for the terminal clamp!!
The terminal clamp is 9-10mm in diameter nternally by the looks of it, the cable core diameter looks more like 14mm.
I've seen some pretty rough looking non mercedes terminal clamps but concered that some wouldn't really be a decent replacement for what was there.
Does anyone recognise the older snapped terminal clamp as I'm suspecting it may be from another Vito model or a Sprinter?
I'm currently looking for the part number as its the correct internal diamter at least and I don't want to replace the whole positive cable.
I've trawled Amazon and Google for quite some days now :-(
Has anyone here also had the same or similar issues, or any experience with the part number I might need to target?
Kind Regards,
TechHead
Bummer, I think I just found the part number which is W6394400027, but also just heard back from the local Commercial Merc dealer and he's spoken to Mercedes and they no longer supply the part ready made :-(
Rather than look to replace the cable, I just want to make sure I can get a terminal clamp that is sufficient for the level of current to the systems, does anyone know of any good brands for trucks or vans they could recommend? Ideally I 'think' I need one that will enable me to solder or hydraulic press, or both.
Insights welcome :)
Just buy a normal Halfords...or where ever battery terminal....the sort with a plate that holds the wires in...strip back all the wire and clamp it up....job done. Battery terminal is a battery terminal.
These quick release type one are the sort we use at work....loads of room for wires in those.....they go under the plate with the two screws.
Nice one Alfa.
Wasn't really too sure about getting a screw down terminal, thought with the amount of current (circa 80amp) that I'd need to ensure the connection was proper solid using solder and hydraulic crimp.
I've ordered something similar off Amazon which I'll use as a temp fix for now, it hasn't got any other posts for the three other cables I need to connect up to the positive feed but will sort something.
Just a thought…
You could use a ‘standard’ battery clamp from an auto electricians or Halfords - the type that clamps the main cable with two screws. The minor cables could be connected via the clamp bolt - perhaps at the square end. If that all makes sense.
Also that main cable looks to be aluminium strands. You won’t be able to solder that into anything.
Edit: think you’ve got it sorted!! 👍🏻👍🏻👍🏻
Will let you know how I get on with the temp fix, need to get f'er running so I can go make some money before Christmas!!
Nice one for the heads up on the solder, crimp it is when I get a terminal suitable.
  • Like
Reactions: Ted
To add more to the mix, just seen advice that you shouldn't use aluminium stranded cable with brass terminal clamps?!
Rabbit hole, but for now will just connect up the s*@t block above and see what occurs once it arrives.
The cranking current will be WAY higher than that ... I would guess 400A or so. Just the glowplug circuit in the W639 (mine, anyway) has a 225A fuse ...
If you can get the main cable off without too much hassle, take it round to your local truck workshop and ask them to crimp you a new terminal on. They will have the correct terminal for the job and more than likley charge you £20 cash.
Nice one BTB, is the 80amp fuse for the SAM module? 400A - Kind of why I want to make sure I do it proper rather than quick fix but will need a quick fix to get about.
Looking at replacement cable which are pretty cheap 2nd hand but just a bit concerned about the potential cable routing.
Can't find anything online at the minute
Cheers Carat, I'm thinking about it to be fair, or replacing the cable with ends already intact
There will likely be a fuse for the starter relay and/or solenoid - could be that. The starter motor itself pulls too much current for a fuse.
So far so good, the terminal was pretty easy to get tight and the screws penetrated the core enough to allow me to put the other positive connectors onto the screw, can't fit the terminal protective cover but it all runs!
Had a few errors on the OBD sensor showing up but managed to clear them and fingers crossed all is good for now.
Cheers for everyone who chucked their two pennerth worth in, it helps a lot, and hopefully gives other people an opportunity to find the thread and fix it themselves for next to nothing compared to the £350+ it would have cost if I'd let the garage have it.
Again, thanks all!
Again, thanks all!
:ttiuwp
Cheers John N, in doing the job was focused on getting it running, didn't think photos at the time but here is the temp fix, solid but going to replace cable at some point. 🤟
When first connecting the battery and starting the van, the error code that came up on my cheap ELM327 OBD reader was this one - P0685 ECM/PCM Power Relay Control Circuit/Open.
Switched engine off, kept ingnition on, cleared the code, switched off ingition and left it overnight with battery connected. Next day engine management light and error code were no longer present, van drives fine and seems a bit more happy with itself ;-)
Audio head unit also had no issues, no code needed or anything so really happy how it turned out. Fingers crossed now!
I still have a couple of small issues remaining which I need to look into after driving to Ikea earlier.
Dashboard error - Seen intermittently for more than a year - Licence plate light - Previously when this happened I'd check, and both licence plate lights were working. Checked today and the right hand side one wasn't so nipped to Halfords and grabbed a couple of replacement bulbs. Didn't resolve it, but the contacts look pretty corroded.
Dashboard error -Error not seen before - Rear nearside light - Checked and all looked to be working fine, will need to look into further.
For some time I've had a nagging feeling that I've got a damaged cable to one or more of the rear lights somewhere along the cable run, like a damaged ground maybe due to ply liners maybe screwing into one of them?
Going to do some research (and take some pics John M ;-)) and see if I can find the issue as it's causing my OCD some restless time.
Anyone else had any similar issues and found a resolution?
The bulb failure system is sensitive and can give warnings before the bulbs actually fail.
Could be worth replacing the bulbs with good quality ones before trying to track down a fault.
Mostly its less than perfect connection between the bulb and the contacts than any fault with the bulbs themselves. just a tiny it of extra resistance is all it takes,
