2013, W212, E250. Battery Voltage Check
Billyboro
Wallasey
W212 E250 AMG
Am I able to check my battery voltage from my dash display on my 2013, W212, E250?
I’ve tried searching on the internet and YouTube but nothing seems to work on my car.
Hope you can help.
Press the R button on/near the instruments three times quickly and voltage will appear on the display.....at least thats how it in on my Merc and most I've seen.
On my S204 2008 C220 with Comand NTG4, key to position 1, hold down steering wheel buttons make/answer phone call, end phone call (both on right) and OK (on left) all together for about 5 seconds, new menu appears in dash, first item highlighted is Vehicle details, press OK and battery voltage and amps useage appears in dash, start engine and display changes to alternator output voltage and amps useage (-ve) or going into battery (+ve). Display continues until either you press back button on steeering wheel or turn engine off.
Thanks for the reply but my W212, E250 doesn’t have an R button.
Oops.....I knew that too!!
Thank you, I’ll give this a try👍
