2014 S212 airmatic malfunction code 557200
PEHARDMAN
UK, CUMBRIA
2014 E220 CDI AUTO SE EST
Hi
I have intermittently had a malfunction warning on the dash (orange car with up arrow) the code is 557200 (correction time when filling too long)
I have inspected the sensors to see that the linkages are connected, which they are. The suspension does not drop and looks normal with no noticeable leaks.
I connected a diagnostic tool which shows the following live data:-
Left Rear vehicle level 5mm
Left rear voltage 2608 mV
Right rear vehicle level -25mm
Right rear voltage 2059 Mv
Both sides change if the rear of the car is loaded.
Questions 1) as the car is loaded the left voltage go’s up and the right voltage go’s down, is that correct.
2) would a good starting point be to change the right hand sensor?
Many thanks in advance.
