2016 A-180 (W176) Rear Lamp Warning - Help
divettri
South Wales
A180d Sport
Hi all, after some guidance if possible........
Was driving & warning notice appeared on dash "Left Side Rear Lamp" (yellow warning colour).
When I got home & checked it, the rear lamp was indeed not working but the right hand side was working fine.
It is some kind of LED strip (so it appears from outside) so I removed the complete assembly to find some kind of circuit board inside at the top. I am not sure if its this that is the issue here so I took some photos (see attached) then put the unit back onto the car.
I then tested it & the dashboard warning had gone so i checked the lamp & it is illuminated again although somewhat dimmer than the right hand side???
Any help as to what i need to do here would be much appreciated.
Buy this and swap the internals over :
Oh ok so i need a new unit then?? Just cant replace single part of my unit?
