2016 GLE350 - SatNav
David404
West Midlands
GLE350d (W166)
Hi all
As above 2016 GLE350 with Sat Nav.
How do I check map version/date installed and what's the most recent version/date?
What SatNav system do you have?
When the unit is first switched on, does it say "Do not let COMAND distract you....", or "Do not let the system distract you..."?
If the former, then you have COMAND (most probably NTG5.x) with built-in Navigation, if the latter then you have Audio20 with Garmin Map Pilot Navigation on SD-Card.
Unknown at moment, negotiating to buy car & will try getting map upgraded if needed.
Oasis report specifies
532 Command on line
815 DVD player.
While you are at it... ask the dealer for both maps update and firmware update for the COMAND unit itself.
Thanks. Will do.
