2017 C43: Front/Rear Camera Issue Helllllllp!
MidlandFox
Leicester
C43 Wagon MY17
Hello all,
My C43 2017 battery went flat, I had to jump start her and then trickle charged her full.
Now my front/rear 360 camera wont work, the sides are both fine!
The rear camera flap operates fine when activating the camera, so no issues there. I had a Google and I saw mention of fuse 417 in the boot, replaced that but didn't help.
Given both the side cameras work and the rear flap is also working, I live on hope that it's just a fuse I need help discovering, seems improbable both cameras got fried...
Any help massively appreciated, as I'm actually trying to sell the car!
Here's a pic:
Off topic . But I'll ask anyways , does your c43 suffer from front tyres crabbing in the colder weather. ?
Hello all,
Here's a pic:
Your Picture shows 180 Degree View, is there a 360 Degree View in the Camera Settings? :rolleyes:
It probably needs a software update.
Why would me jump starting the car create a need for updating the camera modules? Not sure I understand the logic.
You can see the 360 view clearly on the left? The black bits with the non-working front and back camera is the issue.
They seem to "forget" some data when the battery is disconnected.
Ahhh, I see! That's interesting, and also a pain to have to get it booked in if so.
Have you seen this before?
Yes.
Any decent specialist or dealer can help. FYI we charge £50 for each software update. Dealers are around the £170-£200 mark.
Yes.
Had a full diagnostic yesterday, nothing really to report other than my battery was stating it was in poor state of charge (vehicle is largely unused presently), so had it on a trickle charge yesterday hoping that today that would eliminate that as a possibility.
The guys also updated my SVS Module for the 360 and recalibrated the cameras, unfortunately that also didn't help, though the module and hardware report no errors.
Going to try replacing the battery as an additional measure, but I'm really stumped otherwise and feel it could only be a random fuse that's indirectly causing it.
Any other ideas?
Did they check the software for the screen directly as it has its own control unit.
I'll ask him, fitted a new battery and re-calibrated the camera's but hasn't made any difference to the camera function.
Driving me crazy!
Driving me crazy!
I dare say xentry will update any issues directly from the mercedes headquarters. It found my intelligent headlight issues instantly and installed the update. £45 . Session
Driving me crazy!
Check software first and then if that doesn't work look for a broken wire in the boot hinge.
Went for a Star diag today at my local specialist, nothing else showed up that was unexpected.
They did attempt to switch the front camera with another unit, but it didn't resolve the issue. So right now I'm thinking it's the camera control module.
On that note, before I rip apart my car, does anybody know where this is on a RHD W205 Wagon? Led to believe it's the left side of the boot?
Also, does anybody know the difference with the SVS ECU GPS & LVDS versions?
Is there an easy way to check what's in my car from a VIN check?
Sorry, I meant S205, it is the wagon.
Thanks, with this link I was able to confirm the part number I suspected I needed. Ordered a used SVS ECU 360 camera control module off eBay for £47.
Now I just hope if there's any coding needed that it can be done on a Star? Anybody know?
Definitely feeling like I'm dealing with an uncommon fault!
