DannyHall
Alright gents,
Started the car up this morning and there was an on screen warning about the engine coolant level being low. This is far from ideal on the basis that I'm in France and planning to drive back to the UK tomorrow through the Euro tunnel.
Is it normal for it to drop slightly with the colder temperatures? It was 4 degrees this morning. Should a small check and top up be sufficient or should I take it to the dealer to get checked over thus probably meaning I won't be able to travel tomorrow.
If it is just a top up needed (not sure why), what coolant should I be using? Or would some water be sufficient for a quick fix until my service next month?
Dan
Dan
