kevuk20
Hi, is it poss to program the key fob to operate the roof ? or is the smart top module required to make this work ? my SLC does not have keyless option..
Used to be able to operate the roof via the key fob on our ‘58-plate SLK 200. I guess it’s a feature they dropped...Yes, mate - you need the Smart Top to operate the roof. It can’t be done direct from the fob.
On my SL, once I've used the window up button to raise the front window, if I let go then operate it again it raises the rear window. Is the SLK not the same?IMHO the only benefits of the smarttop are the ability to raise the small back windows roof down (which SWMBO would like)
I've only operated the roof on my SLK windows up, it drops both windows a little before operating then returns them to fully up once it's done its thing. I've not tried anything else to see if there is a way of getting the small rear windows back up after lowering the roof, not sure what to try.On my SL, once I've used the window up button to raise the front window, if I let go then operate it again it raises the rear window. Is the SLK not the same?
