202 ,250td not holding charge
John Rodgers
Northern Ireland
1992 190D 2.5. 1998C250TD and 1993 w124 300d estate
could any one help,my c250td,Ihave fitted new battery about six mounths ago,the car goes great when used every day,but left for a couple days the battery is dead,thanks john
Get your battery supplier (or an electrician) to check the battery over,some modern batteries dont last the length of their warranty !
John
Put an ammeter in series onto the battery when she is switched off and lock the car with boot open (if possible) and see what current it draws. That will tell if you have a leak down. Alarms systems have a certain amount of current draw but 2 days is too soon for a flat. Mine regularly sits for 2 weeks as you know.
Also check the charging voltage with a multimeter.
Hope this helps
230k
got it sorted ,non return valve wired wrong way.and draining battery,thanks for your help
