Posted a while back about a slight knocking from the rear on gentle bumps. Anyway problem has been getting worse and I have noticed that the suspension is down on the corner where the noise seems to come from (diagonally opposite corner is up slightly compared with the others as well - to be expected I suppose).
Anyway had convinced myself the spring was broken at one end. Just had a look and can't see anything wrong. Powder coating is peeling away a lot on the top and bottom coils, which as a result are quite rustly, but other than that all looks fine (suspension wasn't compressed at the time of course).
Thoughts? If it's not broken has it just sagged - is this a known problem?
Plan for tomorrow is to slither under the car with the wheels on and compare the coil gaps side to side to see if perhaps one coil has gone "soft". Then I'll check the opposite corner - just in case it's that corner getting pushed up that is causing the opposite rear corner to go down (you never know). Otherwise I'm at a bit of a loss.
