John_Doe
- May 5, 2011
- C32
Afternoon people
Ok I have this problem which is a little hard to explain but I shall try.
when i bought my car it was making a ratling noise from the rear near side wheel. HE told me it was a spring and very simple (which always makes you wonder why he hasnt bothered to do it then). Anyway so after a little looking around I found that my pad is moving nice a freely in the caliper. So everytime i go over a bump the pad bounces up and down inside the caliper making an annoying rattle. I took the pads out and they wernt that old but i noticed that the pin on the fitting kit was moving freely on the pads. So the loop on the back/top (depending which way you look) was larger then it should be and the pin was not holding it in place. So it was pretty much like using a pen to spin a roll of celetape around.
I bought some new pads and a fitting kit and BINGO no more noise! pads sit nice and secure and they dont rattle atall.
BUT!!! It's back now :-(. lasted around a month now its noisy again.
Does anyone have any idea? Oh and if i drive over a bump with my foot on the brake gently the pad sits tight and dont make a noise. So to me it appears that the piston part of the caliper is moving ok.
I got a quote from a local parts place and for me to replace both calipers, discs, pads and new fitting kit will be about £250. Which is reasonable if it will cure the problem but im no mechanic so i dont wanna throw £250 on brake stuff that might not fix the problem when I do have other things that need looking at. I.e Rust, cheap nasty bolt on back back with leaks, strange knock on the front suspension area going over bumps, rear elec window not working, drilled boot lock, door handle broken... actually why did i buy this car!
Anyways! any advice/ opinions would be greatly appreciated
